Anyone Heading To Ubly Saturday?
I will probally be going with a couple of guys from work. Last time out there I had a best of 12.7 @ 107-108 w/4 degrees of knock, but not sure if i am going to run it this week. I just changed the rear gear fluid and found a couple small pieces of broken gear along with the normal shavings. First time being changed 8,000 miles (I would like the stock rear to last me through next year before I go to a 12 bolt). Everything seems ok, I put in about 1 3/4 bottles of Royal Purple 75w90 fluid so far no leaks and no noise. I thought that the stock differential took 2 bottles of fluid, but it started dripping out at 1 3/4 so I plugged it up. Does that sound right?
BTW I hope to see you guys out there.
Marco
Marco
Originally posted by 2001-WS6
It's time for a wheel spinning baptism of the new setup with Nittos.
So I'll be heading up there too.
Rick
So I'll be heading up there too.Rick
With THAT Beast! I know Ubly hooks . . . but . . .!See you guys there! Hope the weather does hold out!
Mark
Sorry Hink! I'm pretty sure it's just a fun deal and there's no prizes. I think it will be kind of like the St. Thomas event. We are going on a regular test and tune day so anybody can show up. I'm not exactly sure if there will be any actual bracket racing or not. There might just be a few grudge matches here and there but otherwise it's normal test and tune. I wish I had more details for you.
I won $400 at the Stanton event MTM had.
My car is down for the count, at the moment. Reconstruction surgery.. Hopefully I'll see you guys at M7.
Maybe if I get the IROC-Z done, I'll swing up to Ubly. Good luck to everyone.
Bishop how did you register in Jan 1970. I just saw that under your name .
Check with me I may try and follow you up there. I would like to do some test and tune before M7. I have not been to the track this year. 558/6694.
The weather said today that it would be partly sunny Sat and Sun.
Check with me I may try and follow you up there. I would like to do some test and tune before M7. I have not been to the track this year. 558/6694. The weather said today that it would be partly sunny Sat and Sun.
Damned if I know Chris, I must be old school like Junior High
(Says Dec 1969 now, hahaha I must be getting older as I type). I'll give you a ring Friday night if I have a game plan. If you don't here from me give me a ring 362-3516. I was thinking about leaving somewhere aroung 11am. Yeah I hope the weather holds,seems like a different forcast everyday.
[New Jersey] Cure those winter blues with the NJFBOA!!!
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
