Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Anyone got a TIG welder? I need some help
Old Mar 9, 2003 | 01:00 PM
ws6transam's Avatar
I've got a Chomemoly roll cage coming but I'm out of money and need some help installing it. Is there anyone close that is willing to lend me a hand with the TIG welding?
Old Mar 11, 2003 | 01:24 AM
AL SS590 M6's Avatar
Moderator
Aer you stuck on using a TIG?
I just bought a new MIG that would do a great job.
ps. you never did send your address.
Old Mar 11, 2003 | 06:30 AM
Grover's Avatar
Al,
If I'm not mistaken with the chromoly cages they have to be TIG welded to be legal.
Old Mar 11, 2003 | 07:04 AM
Black Sunshine/ 00SS's Avatar
You are correct Chad. Sorry Dan, dont know anyone with one of those.
Old Mar 11, 2003 | 03:13 PM
maniacc's Avatar
If you can get the car down to Carleton (near Monroe), i have a friend that can and will TIG in your cage for ya...
Give him a call Doug @ 734-654-6263,
He has a ton of experience in chassis and cage work.
later
larry
Old Mar 11, 2003 | 05:40 PM
streetbad's Avatar
I will be glad to give you a hand.
Old Mar 11, 2003 | 10:39 PM
ws6transam's Avatar
Thanks for the help suggestions! I'll be giving you all a call. I have one fellow here locally that welds on the Cyclotron at MSU, but if he doesn't call back, I might be making that trip.
I'm taking the interior out right now. (Welll, not *right* now). I've only found one little spot of rust so far, and it's amazing how shiny those 19 year old panels look under that carpet!
Hafta be careful though... 19 year old plastic can break easily.
Old Mar 11, 2003 | 11:52 PM
Moderator
Originally posted by Grover
Al,
Why? Who says so?
I know that chrome moly is an alloy tube. Steel, chromium, and molyebedinum (sp). But why can't it be mig welded with the correct wire?
Inquireing minds need to know.
Old Mar 13, 2003 | 11:36 PM
Moderator
Question
Why? Who says so?
Does anybody know the answer to the above questions?
Old Mar 14, 2003 | 06:33 AM
Grover's Avatar
Originally posted by AL SS590 M6
Why? Who says so?
It's in the NHRA rule book. If you are putting a bar in why not make it legal.
I believe it has something to do with the depth of the weld. I will do some checking and find out more.
Old Mar 15, 2003 | 06:45 AM
Moderator
Chad it's not that I don't want to do it right, safe, or legal. It's that I don't understand why TIG only. Just looking for clarity. And the reason isn't depth of penetration. That is controlled strictly by voltage/amperage. I can get the same depth with any kind of properly sized welding machine.
I would really appreciate that.
Old Mar 15, 2003 | 09:35 AM
Grover's Avatar
I am still trying to find out for sure, but what I have learned from a journeyman toolmaker friend of mine is that with TIG welding chromoly you have to use filler rods (kind of like ARC welding) but with the gun of a MIG welder. He said that you can get a conversion kit for a MIG to make it a TIG, this changes the tip on the gun so the arc comes out of the gun and you use chromoly filler rods for the material. Whereas in MIG welding you are using the wire as the filling material.
generaldave
Sep 25, 2015 06:48 PM
JordonMusser
West South Central
Nov 17, 2003 08:15 PM
1994TransAm
Nov 2, 2003 10:31 PM
jimlab
Advanced Tech
53
Aug 11, 2003 12:51 AM
ws6transam
3rd Gen / L98 Engine Tech
May 10, 2003 10:01 PM
