Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
anyone got a stock tank i could get off them?
Old Apr 4, 2008 | 12:34 AM
limige's Avatar
i'm looking to sump the stock tank, i want to do a quicky switchout so i'm looking for someone parting a car or something that happens to have a tank available. actually if you scrap one you'd have to pull the tank as well..
anyway, email me if you got one
limige1@aol.com or call me 313-515-3720
thanks
mike
Old Apr 4, 2008 | 06:34 AM
IrocSS85's Avatar
got a 3rd gen tank if that would work for you. Im positive it will swap right in , just not positive the resistance range on the float is the same. might have to swap/modify the sender for your float. $50 and its yours if you cant find any 4 gen tanks locally.
chris
thanks
mike
Old Apr 4, 2008 | 06:43 PM
limige's Avatar
thanks i'll keep it in mind, not sure my senders any good as it is. long story.
Old Apr 4, 2008 | 07:01 PM
IrocSS85's Avatar
I might have a 4 gen float if thats what your needing, or is it the part with the fuel lines? cause you wont need that with the sump, except to seal the hole and hold the float. lol.
Old Apr 5, 2008 | 08:28 AM
limige's Avatar
well the gas gauge hasn't worked right since i pulled the factory stuff out and now the wires are melted. so yeah, i need the tank with the sender unit...i thought most all GM senders were the same, 3rd gen's aren't different from 4th's are they?
Old Apr 5, 2008 | 12:11 PM
IrocSS85's Avatar
pretty sure the LT1 tank is the same. the sender is different though. but all you need is the float in there right? your goin to have an external pump after the sump right?
Old Apr 7, 2008 | 05:07 PM
limige's Avatar
yes i have an a1000 in there, i'm reworking feed and return locations. no i need the whole sending unit, not just the float.
Old Apr 7, 2008 | 06:28 PM
IrocSS85's Avatar
dont know if your still interested, but Im planning on goin out to pick up my Iroc this weekend to bring it home finally, and the tank is out there with the car in storage way down in dundee. so let me knw if you are still interested and I'll bring it back home. and see if I still have the sending unit in the tank. but I dont think so for some reason.
how much is the sump and welding goin to cost you? or are you goin to weld it yourself? cause they do make an alum. tank for the 4gens that would bolt right in but its like $500 or something. but might be a better alternative for you if you were planning on paying a shop to weld in the sump and modify the sending unit after you buy all that.
Old Apr 7, 2008 | 11:12 PM
limige's Avatar
thanks for the offer but i found someone in clio that's putting a cell in their car. we just need to work out a price and date for pickup.
i've got a fantastic welder at work that can weld anything i need done, so i've got that covered.
i'd rather not try a 3rd gen tank, did that once with a rearend and it cost me way more than anticipated. i just want a simple swap out seeing i have to drop the rearend and everything to do it.
Old Apr 8, 2008 | 06:07 AM
IrocSS85's Avatar
cool, understandable.
canbaufo
May 25, 2015 12:01 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Deadbolt24
Jan 19, 2015 01:29 PM
