Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
[Michigan] 95 Z28 $5500 obo
Old Apr 23, 2011 | 11:03 AM
MichiganSkip's Avatar
95 Z28 $5500 obo
1995 Z28 Camaro Red w/black top and T-Tops. Paint is in good condition, Stock LT1, less than 65K on car. Burns no oil, no leaks, AC needs charged, manual windows, mirrors. T-Tops dont leak. Brakes in good condition. Gray leather interior, no rips or tears
4L60E w/3200 converter and 4.11 gears
Stock motor, throttle body, and cam.
Heads untouched.
Mods: Mallory 685 box wired up and using the 2 step, rev limiter, high speed retard and window switch to control the nitrous Pacesetter long tubes coated.
Exhaust is a single bullet with turndown before axle.
EGR, Air pump, cruise, TC deleted
Line lock
Taylor OVC wires with heat shields on boots.
BMR subframe connectors, double adjustable Lower Control Arms, HAL 12 ways on back
UMI torque arm and re-located off trans (with DS loop)
Prostars on all fours with MT front runners and new M/T Sportsmans on back
New nose and VFN pin on 4inch cowl hood.
NX kit mounted and plumbed thru relays and ready to go.
DynoJet WB installed
New Bosch III 28lb.injectors
Still gets 19mpg on the hwy.
Located in SW Michigan. 30 miles from South Bend IN, 90 miles from Chitown.
$5500.00 obo.
Old May 6, 2011 | 12:29 AM
94QuasarZ's Avatar
Re: 95 Z28 $5500 obo
Interested in any trades?
Noenav
Mar 1, 2019 07:38 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
alphaauto
Jan 23, 2015 07:42 AM
Elcojoe
Nov 17, 2014 10:27 PM
