Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
350 chevy vs Opti vs LT1 computer system
Old May 31, 2005 | 10:48 PM
Firebird355's Avatar
Ok, all I need to know is, is it possible to run the LT1 harness and computer on a Gen 1 SBC and use a regular distributor.... or would you HAVE to use a DFI system or something. Dont say it wont work with heads and intake as this will be a very custom setup.
Thanks,
Joel
Old May 31, 2005 | 11:00 PM
Mike94ZLT1's Avatar
Re: 350 chevy vs Opti vs LT1 computer system
I dont see why not, theres guys on here that run LT1's with regular distributors in modified manifolds, but I also think they still use optis so the internal sensors can be used as reference for fuel.
Old Jun 1, 2005 | 06:30 AM
Yea Im talking using a gen 1 block, with no opti and a dist but still using the computer from the lt1 to run the system, I dont think its possible, i believe the only way to do it would be to use a DFI
Old Jun 1, 2005 | 07:37 AM
1994TransAm's Avatar
go buy computer from a 96 gm truck or so... somehing like that.... they use everything you want!!!!
then get a tunercat def! file for the truck, and boom... your done!!!!
no opti, old sbc
Old Jun 2, 2005 | 07:00 AM
interesting.... so basically I would use my harness?? and then I would have to find the software for tuning a truck??? more info on that software and files... I have tunercat, just need more info. Thanks
Old Jun 2, 2005 | 10:19 AM
you need a modifed LT1 intake for use with a rear mounted Distributor, the computer system and harness from a truck (reasearch which one first) and then do the swap!!!
look for a 2 wheel drive truck, less harness to worry about...
pcm
harness
front timing cover with cam sync sensor(from a 96+ LT1)
intake!!!
done!!!!
i'm selling an intake modified for this exact purpose, let me know if you want it!!!!
i'll ask my ECm guy ... find out what you need exactly!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Dec 6, 2014 05:20 PM
Jul 4, 2005 05:00 PM
