110 octane leaded or unleaded
The sunoco on m59 in waterford carries 110 octane , if this is leaded will it harm my engine (I don't have cats). Also I'm getting a tnt wet system and was planning on using ramchargers timing tuner just to be safe. Could i dump that and just use high enough octane and be just as safe? thanks
mike
mike
yeah, dont use leaded fuel. its for cars w/o o2 sensors. just use octone booster instead. as long as its unleaded that is. Ive never read one of those bottles to see if its leaded or not. how much spray are you gonna use? if its 125 or less, you wont really need to lower the timing. just make sure its got premium or unleaded race fuel in it.
chris
chris
..or, if the car is "tuned" correct you could run the car in "openloop" and the o2's are not an issue.
HRH, run's open loop tune
and bus loads of that heavy weight fuel.hahahaha
What sunoco on m-59 has the 110?
is it between airport and cresent lk rd?
and bus loads of that heavy weight fuel.hahahahaWhat sunoco on m-59 has the 110?
Q
Originally posted by dreamer1q
Hey Hawk, how about a little more info on this "tune" I am having problems with the o2's and the oppurtunity to eliminate them makes me smile!
Q
Q
Timberwolf is correct on the open loop mode.
Just raise the "coolant enable mode for closed loop" to the highest value it will take. Then the car will never get that hot and it's open baby.
I spent probley 25+ hours tuning the "Openloop AFR" fuel tables with a wideband o2 box on the car to get the job done.
The following were where the factory o2's values reside while in operation "openloop".
At idle she's .450 mv
at light load cruise= .600~.680mv
moderate load cruise= .680~.750mv
wot horsepower= 855mv
wot nitrous=885mv
any decel the o2's will be around .200~.300
You will loose some gas mileage running open loop but I still pull down 19.5 hwy in open, but in closed loop it get's 23~24 mpg!!
which is bad azz in my book when you run a cam that's 262/268@.50, 647/685 lift, 113 cl, on a 114lsa
wot nitrous=885mv
Thanks for all the replies, I was planning on using the 150 shot
Hot Rod Hawk: I'm new to the waterford area and don't know the crossroads yet, the sunoco is about five miles west of of telegraph
Henson071
Aug 4, 2015 09:32 AM
