rochester area - anyone help with cam swap?
okay, wondering if anyone in rochester area wants to help with my cam and rocker install next weekend (most likely if parts all come in)
i have never done a cam install or rockers , especially in a the nice spacious LTI engine bay - anyone have experience and want to give a hand? ill buy beer and pizza- its a 97 z28 - fenders and front bumper will be off (replacing from accident) will be installing : ------------------------------------------------ Comp Cams 26918-16 springs Comp Cams 787-16 retainers Comp Cams 601-16 valve locks Comp Cams 1305-16 rocker arms ARP 7/16" studs Valve Seats AFR guide plates Comp Cam Pushrods Comp Cam XE 230/236 112 lsa cam timing chain Airfoil Taylor OVC 8mm wires 4 sets of rotors and pads alignment Powdercoating timing cover- intake manifold - waterpump - and alternator bracket while they are off (buddy has oven to powdercoat) new horns new front bumper cover new right fender new headlight bar clear corners ----------------------------------- ha i think thats everything.... lot of stuff piling up in my apartment - should have all the gaskets and fluid too. My friend jeff will be helping - ideally we might be able to use his shop - which means will have car on lift and all the mechanic tools we would need. Once we pull covers and manifold off he will run home (15 min away) and powdercoat everything while we are finishing up the swap. If that doesnt work out- my friend has offered his garage which is 5 min from the shop - so we can just run back and forth if somehting is needed- so who's interested in a record setting rebuild - im hoping to get it torn down and running by end of night- so i can sneak it to my friends garage to finish the bodywork the next day- It would help out immensely if someone knew exactly what they were doing with us- nothing like someone with experience |
