ZR1 wheel & tire size? How Big?
Old Apr 6, 2004 | 10:19 PM
Smokn '94 Z's Avatar
I have the 17 x 9 ZR1 style wheels. I wanna get some Nitto's for the rear. What is the largest size tire I can mount to the 17 x 9 rim?
Thanks.
Old Apr 6, 2004 | 10:23 PM
GreenDemon's Avatar
I would say 275s would be your best bet. Bigger would probably stretch the tires in ways that would not be good for handling, and possibly void any tire warranty as well.
Old Apr 7, 2004 | 12:36 AM
CamaroSS30thAnn's Avatar
275' i sthe max for 9 inch rims
Old Apr 7, 2004 | 02:11 AM
Steve in Seattle's Avatar
ZR1's used 285's on there fronts, but they're 17.2x9.5" rims so that's probably why.
When I took off the stock 285 GSC's and mounted some 275 Eagle F1 GS tires in their place the handling was noticeably more precise and had little "sponge" feel left in it.
The 17x11" rears will fit 285's as well BTW. Much stiffer than stock, and feels real good on corners. The 315's that came on them were slick looking, but I think I'd be happier with 305's on my next set. Too bad Nitto doesn't make a 305... so I'll probably get 315's anyway. (There's no way I'm gonna try stretching a 275 on there, regardless of what the manufacturers say ).
Old Apr 7, 2004 | 03:16 AM
Kataklysm's Avatar
I had 315s on my 17x9, the rears rubbed the inside of the wheel well though (I didn' put them on) Now I run 275 all around.
Old Apr 7, 2004 | 03:49 AM
Xride's Avatar
285s on the ZR1? even being a 9.5" they had 275 from the factory.Comp TA's, They fit perfect.
unless your not talking about the zr1's that came on the SS's
Old Apr 7, 2004 | 05:33 AM
GreenDemon's Avatar
285s on Corvette ZR1?
Old Apr 7, 2004 | 07:04 AM
Coolformula's Avatar
I got my zr1 last week 17x9.5, the largest tire recommended by the manf for 9.5 is a 285 series( i have run 285 on a 17x8!!!!, so 285 fit fine. I like them.
Old Apr 7, 2004 | 08:18 AM
Zepher's Avatar
My friend had some 315 Nitto DR's on his 99 SS ZR1 style wheels. Shoulders bowed out a bit and rode ok with normal psi but when it was lowered at the track, it felt to squirrely. Everytime I'd shift it felt like the rear end was going to swing out.
dpw21562
Jan 23, 2015 04:58 PM
hotrodyou1
Dec 20, 2014 10:05 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
kizz
Jul 6, 2002 11:03 AM
