Zexel Torsen T/O differential
Old Nov 10, 2003 | 12:59 AM
drewstealth's Avatar
I was just wondering if anybody has tried one of these from SLP. I think my differential is messed up on my car because when i turn from a stop and give it gas my car shakes really bad. It is only like $120 or so. I was thinking i could try this and put some 4.10's in there while i'm at it.
Old Nov 10, 2003 | 06:11 AM
2cub49's Avatar
I have the tosen carrier with my 3.73's`and it works great. No posi fluid to add and no clutches. It uses roller gears that look like big needle bearings.No problems whatsoever.
Old Nov 10, 2003 | 06:41 AM
WOT's Avatar
WOT
I have one in my car. You'll have to replace the carrier bearings and inspect it carefully. SLP basically just throws these off the car. The bearings on mine weren't good (not a big deal) and I had to file down some spots on the flange that the ring gear bolts to. The carrier had been dropped on the floor by someone. Other than that it works great, especially for ~$100.
Old Nov 10, 2003 | 07:40 AM
Grease's Avatar
Mine lasted 8 months. Now I'm back to 1 wheel burnouts
Old Nov 10, 2003 | 07:53 AM
CANTONRACER's Avatar
I got a couple of years out of mine, a bunch of 1.6 60's..blah..blah...now I have a Eaton sitting waiting to be installed.
Save yourself some money in the long run and some time.
Get a good diff unit.
Old Nov 10, 2003 | 09:28 AM
WOT's Avatar
WOT
How does a torsen wear out?
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
96cam4ro
Jan 24, 2003 03:06 PM
94-3.4
V6 Tech
Oct 19, 2002 12:18 PM
