z28 transmission
z28 transmission
Hi i have a 1995 z28 convertible with automatic transmission car has 100000miles,when driving it stalls slightly to put second gear but after that runs perfect is this a serious problem,just bought the car any advice on what to look into to fix to avoid future problems thankyou
Re: z28 transmission
Could you clarify exactly what happens when "it stalls slightly to put second gear ". Do you mean it seems to hang up before it will shift into 2nd; it goes into neutral before it shifts into 2nd, etc?
Fluid level is correct, and fluid does not look/smell burned?
There are codes for the 4L60E trans. They don't turn on the SES light. So you have to scan for them. This is a problem with a 95, because it has a 16-pin OBD-2 style ALDL connector, but an OBD-1 PCM. Here's free software download. You just need a cable.
https://www.camaroz28.com/forums/com...95-lt1-874306/
I checked the fluid and it looks burned,if you could tell me how to change id really appreciate it and whats the best fluid to use,i also checked my radiator and it has alot of rust any advice on how to clean it out ?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
