Z28 Engine trouble, please help
Old Jan 22, 2008 | 11:40 PM
Bowen292's Avatar
One day I was driving in heavy rain and while I was idling, I noticed the engine having trouble...rpm needle was moving, and battery voltage was lower than normal, and i could definite tell something was up. Even when i was driving around the engine was having trouble responding.
i went home and I got a code for my 1997 Z28 and it says "random multiple cylinder misfire"
I have noticed that my car acts this way usually only happens when it is raining out. I had driven it for a solid week in dry weather and it ran fine...then it rained again heavily today and i had the same problem.
Have any ideas what it could be? I honestly have no idea were to start looking for the problem, i know a little about the LT1, but not too much.
Old Jan 22, 2008 | 11:52 PM
billymz28's Avatar
sounds like moisture in the opti aka distributer . A common problem. You have a 97 so you have the vented opti make sure the vaccume hoses are on the opti good and snug and you may want to consider pulling the opti and sealing it better.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
