your opinions please
Old Apr 11, 2003 | 08:40 PM
detska's Avatar
my 94 z28 a4 has a constant misfire type thing. when first started up, at idle and at any and all rpm. so far i have replaced the o2's and checked the wires for arching. i am thinking that it is my opti but the posts that i have searched about the opti always attribute it to a certain rpm or rpm band. can the opti cause a constant stumble/miss at all times regardless of rpm/gear? i am a bit of a newb to the car thing so i would greatly appreciate any and all ideas.
thanks!
Old Apr 11, 2003 | 09:19 PM
Teek's Avatar
Time for new spark plugs?
Old Apr 11, 2003 | 09:37 PM
detska's Avatar
could the plugs being fouled make that much difference ?
it's a pretty violent shake coming from the engine.
Old Apr 11, 2003 | 10:06 PM
You may even have an open plug wire. Plugs and plug wires would be a good thing to do if there are many miles on them. Also check all connections on the coil.
Old Apr 11, 2003 | 10:43 PM
detska's Avatar
the plug wires are ok i have alredy checked them and they are only two weeks old.
and everything is hooked up tight and screwed in all the way.
can an opti miss all the time? is that an opti symptom? or is it always an intermittent miss?
from what i have read it is more of an all or nothing deal with the opti.(it works or it doesn't)
Ks0209
Oct 1, 2015 07:32 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
jackpawt883
Jul 31, 2015 08:15 AM
birdblack
Jul 8, 2015 07:23 AM
