You Want to Know What Size TB to Get? Here=
Old Nov 6, 2003 | 02:43 PM
  #16
kmook's Avatar
Advanced Tech Moderator
Originally posted by Birdie2000
Now how do you figure forced induction into this?
Up the VE percentage in the first formula.
Old Nov 6, 2003 | 02:46 PM
  #17
Birdie2000's Avatar
How do you determine how much of an increase?
Old Nov 6, 2003 | 03:48 PM
  #18
LT4POWR's Avatar
Good info. I kinda figured my stock TB might be holding me back a little. A bigger throttle body is definitely on my Christmas list.
Old Nov 6, 2003 | 04:14 PM
  #19
CamaroGuy22's Avatar
At what RPM does a stock A4 shift at?
Old Nov 6, 2003 | 04:18 PM
  #20
stereomandan's Avatar
Looks like the stock one is already a little small for stock engines. I get 577 cfpm with 100%VE for a stock engine.
Doesn't valve lift and come into play?
Dan
Old Nov 6, 2003 | 04:33 PM
  #21
Transamdriver's Avatar
Well crap I need 658cfm just on engine alone. Im still using the stocker.
Old Nov 6, 2003 | 04:35 PM
  #22
Kain's Avatar
5700 1-2
5800 all other gears.
Old Nov 6, 2003 | 05:16 PM
  #23
lt4 fd's Avatar
what does a typical 52mm like a bbk or a ported stock one flow about?
Old Nov 6, 2003 | 06:24 PM
  #24
BlackDog's Avatar
Ken, thanks for the info. By the way, I took a peek at your website, I love the opening picture. LOL That really somes it up. If that damn thing would fit I'm sure someone would bolt it on.
Scott
Old Nov 6, 2003 | 06:27 PM
  #25
kmook's Avatar
Scott
LOL thanks. Yeah i actually need to get around to updating since i dont even have that SS anymore.
Old Nov 6, 2003 | 07:35 PM
  #26
BlackDog's Avatar
Originally posted by madwolf
Thanks for the info, Ken.
Any idea what the typical 52 mm flows?
How about a 48. 550 if I remember correctly?
52 mm flows 790.
Old Nov 6, 2003 | 07:40 PM
  #27
NOMAD's Avatar
52 mm flows 790.
Actually, BBK advertise 750. Ours flow in excess of 775-800 depending on the work done.
-Shannon
Old Nov 6, 2003 | 07:54 PM
  #28
gixXxinRS's Avatar
hey nomad i sent you a pm..
Old Nov 6, 2003 | 08:29 PM
  #29
Originally posted by Kain
5700 1-2
Thank you! I know our stock tachs are not dead on, but while racing it appears that my tach goes way past 6, is that right? Since it should be shifting below 6,000 rpms? Anything to be concerned about?
Old Nov 6, 2003 | 09:33 PM
  #30
magius231's Avatar
your probably asking for trouble using 100% VE in this calculation...a typical engine will only be in the high 80's maybe 90's, and that can make a large difference in how much airflow it actually needs. Boosted apps can exceed 100% VE by quite a bit.
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
