year of lt1 need help
Old Oct 24, 2005 | 08:39 PM
99s10lt1's Avatar
how can i tell what year lt1 i have its out of a wrecked roadmaster someone told me the comp was from a 96 but r their other ways to tell by looking at the motor itself
Old Oct 24, 2005 | 09:05 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Re: year of lt1 need help
Well if your comp is an OBD2 then its a 96 or 97... But as far as the engine goes... Doesn't it say somewhere on the underside of the block??
Old Oct 24, 2005 | 09:09 PM
99s10lt1's Avatar
would that have a vented opti and a long or short pin on the cam
Old Oct 24, 2005 | 09:23 PM
Somebody correct me if im wrong but im pretty sure that the first year of the vented opti was 95
Old Oct 24, 2005 | 09:28 PM
99s10lt1's Avatar
thanks for the info
Old Oct 24, 2005 | 11:51 PM
sbs's Avatar
sbs
96+ has crank position sensor
95+ has 2nd gen optispark
94+ has fuel rail with crossover
92-93 not sure if there's differences
Old Oct 25, 2005 | 07:36 AM
F-bodies have a VIN derivative stamped on the engine. I would imagine the Roadmaster engine has one, but I don't know if the codes are the same.
Old Oct 25, 2005 | 08:06 PM
96capricemgr's Avatar
ALL b-bodies 94-96 got the vented opti, yeah we got it before the Vette and f-body.
If it has no CPS it is a 94-5 if it has a CPS it is a 96.
I am sure the VIN derivative is there too just I never looked at it.
FYI 94-96 the LT1 was the one and only engine option for the Roadmaster and Fleetwood, so they can be good sources especially seeing as the price is usually reasonable because they are not seen as "performance" cars. They got the same exact engine as the Impala SS or the optional LT1 in the Caprice cop cars but without the extra pricetag the ImpalaSS name would command or occassionally the "cop engine" price tacked to a 9C1 engine. Granted they are iron heads which many of you write off due to ignorance but the shortblock is identical to the f-body.
Old Oct 25, 2005 | 08:18 PM
turbo_Z's Avatar
*courtesy of shoebox*
The part numbers for the LT1 ECM/PCMs are:
93=16159278 OBDI
94=16188051 OBDI
95=16188051 OBDI
96=16214399 OBDII
97=16242921 OBDII
The number is on the back of the PCM. But yeah the CPS sensor is a dead give away.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jul 4, 2005 05:00 PM
