Y-Pipe question
Is there a Y-pipe that can fit up to the stock manifolds on a 97 dual cat Z28? What I'm after is a Y-pipe merging into one pipe, going into one catalytic converter, then out to a catback.
I would really like to start figuring things out tomorrow (Tuesday). Quick replies are very appreciated :) I made a thread down in the exhaust section, but it doesn't seem that users frequent that section much. https://www.camaroz28.com/forums/sho...d.php?t=549298 |
Maybe I had too many beers,but the 97 came with the bigger Y-pipe,and a single cat.Did you buy the car used?Maybe the previous owner dueled the exhaust or something.If my memory serves me right,only the 95's had the dual setup.Hope this helps.(California).With a Catco cat,and an intermediate pipe,might pick up 7 ponies.(But this advice comes from a guy who took his remote car door opener controller apart to clean the terminals,and busted it,and had to get a new one from Dal.)(Dealer$140.)Dal,$50.00)Hope this helps.
96+ had dual cats
if you really wanna go to the single cat setup, and a 93-95 y pipe wont fit, just cut out the cats and weld in straight pipe where they are, then put in a cat back after the y |
2 cats?In the same line?I dunno.Bare with me ,I'm old.
1st cat by the drivers side manifold 2nd cat before the 2 into 1 collector of the ypipe
Originally Posted by CK9192004
(Post 4942620)
| All times are GMT -5. The time now is 09:36 AM. |
