Y pipe clearance ?
Old Apr 6, 2005 | 03:07 PM
Z-RATED94's Avatar
Y pipe clearance ?
Would it be ok to lower the trans crossbrace about a quarter of an inch? I'm having problems with Pacesetter Y pipe on the drivers side. It's resting on the floorboard and making quite a racket. My thought is, if I can change the angle of the motor and trans slightly, I'll have the clearance I need.Taking a hammer to the floor board is not an option. I do have an adj. torque arm, so getting the pinion angle correct should not be a problem. TIA
n2oblkz
Oct 12, 2015 01:53 AM
Ks0209
Oct 1, 2015 07:32 AM
greenzee28
Sep 25, 2015 04:29 PM
Z Power
Sep 19, 2015 11:19 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
