XE224/230 110LSA, stock heads dyno results!
Old Aug 17, 2004 | 12:08 PM
turbo_Z's Avatar
Well after a year of running this cam I finally decided to see what it could put down on the dyno. Here's the chart. If you dont feel like looking at it.. I put down 338hp/339tq spinning the motor to 5500 rpm. Had I gone to 6k I am sure the hp numbers would be higher since the run before this and prior to some fuel tweeking I put down 335 hp at 5800 rpm.
Old Aug 17, 2004 | 12:09 PM
texasTA's Avatar
Re: XE224/230 110LSA, stock heads dyno results!
Damn, that is pretty impressive seeing that you only spun it to 5500rpms. Nice.
Old Aug 17, 2004 | 12:11 PM
RealQuick's Avatar
It looks like a the 338rwhp was a spike looks more like a soli 330rwhp. I dunno...JMO.
Old Aug 17, 2004 | 12:16 PM
turbo_Z's Avatar
I noticed that too but on my second run which I dont have scanned to show, the graph didnt spike like that and showed 335 rwhp.. the graph I hosted is 5-10 rwhp in more in spots across the board.
Old Aug 17, 2004 | 01:42 PM
Mindgame's Avatar
Originally Posted by turbo_Z
Well after a year of running this cam I finally decided to see what it could put down on the dyno. Here's the chart. If you dont feel like looking at it.. I put down 338hp/339tq spinning the motor to 5500 rpm. Had I gone to 6k I am sure the hp numbers would be higher since the run before this and prior to some fuel tweeking I put down 335 hp at 6800 rpm.
No sense stressing it any more than is necessary. 335 @ 6800... she's probably given up way before if you're using the 224 in a 350.
The numbers look great though, considering the work. I bet you could get another 40-50hp out of that with some good head work and tweaking.
Good luck.
-Mindgame
Old Aug 17, 2004 | 02:00 PM
turbo_Z's Avatar
Good luck.
-Mindgame
That was a typo.. Theres no way Id ever intentially spin it to 6800. What I meant to say was 5800.
Old Aug 17, 2004 | 02:05 PM
kevmor99's Avatar
Is this a hyrdualic roller cam? Whats the part #?
Old Aug 17, 2004 | 02:08 PM
30thCamaroZ's Avatar
Are these stock unported heads or do they have some port work done to them? I'm in the middle of a 355 LT1 build up for my 3rd gen and am having a 3 angle valve job done and doing some port matching but can't decide on what cam I want to go with that's why I ask.
Old Aug 17, 2004 | 02:25 PM
turbo_Z's Avatar
The heads are stock and this is a hydualic roller cam.
Old Aug 17, 2004 | 03:15 PM
DZNUTTS's Avatar
Those are some nice numbers,with some stock heads...
Old Aug 17, 2004 | 03:24 PM
zlightning's Avatar
Wht other mods do you have done?
Old Aug 17, 2004 | 03:28 PM
Somnambulist's Avatar
geat looking HP number, but the torque seems a bit low. I dyno'd the numbers in my sig with stock heads/cam
Old Aug 17, 2004 | 03:37 PM
speed_demon24's Avatar
Links down.
Old Aug 17, 2004 | 05:40 PM
turbo_Z's Avatar
works fine for me.
All other mods are listed in my webpage.
Old Aug 17, 2004 | 05:46 PM
95LT1Z28's Avatar
Nice numbers! I have the same cam (except for a 112 LSA) with stock heads and I put down 331 RWHP and 343RWTQ. LT1's are too much fun!
Jeff
