XE Lobe Limits
Re: XE Lobe Limits
Originally Posted by OffspringZ28
1.9?? never heard of that on an LT1. might be some valve/piston clearance issues with that.
Re: XE Lobe Limits
why do you have to rev to 7200? if you have heads that are flowing that well, you'd be better off just getting a solid roller top end to keep up with them, and make sure you bottom end can handle rpm's that high.
i don't know of any hydraulic roller cams that pull to 7200.
i'm really interested in knowing why you have to spin that high?
Re: XE Lobe Limits
Re: XE Lobe Limits
forced induction car....that makes a little more sence. either way, a cam that small can't keep up to that high RPM. like brett said, once you get into something over a 1.6 rocker, you start getting into more problems than the perspective gains are worth. your best bet would be to call comp cams up (1-800-999-0853) and tell them what you're looking for in a cam, and let them grind one out. you'll spend about the same amount on a new cam and intall than you would changing everything neccesary to compensate for that long of a rocker, not to mention you'll make more power with a purpose specific custom cam.
Re: XE Lobe Limits
i was just browsing through the for sale section, and there are two blower cams for sale. one from cam motion looks like a really good cam, and judging from the specs, it'll most likely pull you close to what you're looking for on a 1.6 rocker
Re: XE Lobe Limits
Calling Comp will get you a "best fit" catalog cam. The same is true from many people who claim to offer "custom" cams. They spec the same lobe for a 3000 lb 6-speed car as they do for a 3400 lb auto with a tight converter. That's simply not "custom".
More lobe area is likely what you want but you need to talk to someone who can set you up with not just a cam... but the components to make it live. And yes, there are a number of hydraulics turning ~7k these days without all the tricks we used to resort to. Gotta love technology.
-Mindgame
-Mindgame
Sep 11, 2015 09:44 AM
