WTF!? Look at my MAP sensor!
Old Apr 16, 2004 | 10:59 AM
Cmr0z28's Avatar
Look at the seal! You can see all the crap on the corner of it, I'm guessing that's my vacuum leak right there?
http://images.cardomain.com/member_i...1_291_full.jpg
http://images.cardomain.com/member_i...1_292_full.jpg
Old Apr 16, 2004 | 11:03 AM
Cmr0z28's Avatar
How much is a new MAP sensor? Part numbers anyone???
Old Apr 16, 2004 | 11:28 AM
IslandZ's Avatar
The funny thing is that a new map sensor does not come with the seal!
Just get an o-ring at te parts store.
Dont bother changing the sensor if it still works ok.
Old Apr 16, 2004 | 11:33 AM
LeeS's Avatar
Hi Matt!
Just call Jason Cromer and tell him to order you the O-ring or Grommet for the Map Sensor because a new sensor won't come with one.
No use in replacing sensor unless it is bad!
Have a goodone Lee!
Old Apr 16, 2004 | 12:02 PM
Cmr0z28's Avatar
Ok thanks....
What should I use to get all the carbon off? A tooth brush and carb cleaner?
Tim240z's Avatar
Hell...mine was the same way...I just put a bead of Hylemar around the rubber seal and reinstalled it.....
Tim
Old Apr 16, 2004 | 12:08 PM
Cmr0z28's Avatar
Hylemar? What's that?
I don't want to use anything that will get sucked into the intake...
Can I get this rubber seal from anywhere else? Jason Cromer isn't in, I just called.
Old Apr 16, 2004 | 12:23 PM
Tim240z's Avatar
Hylemar is a non-solidifying sealant and is not effected by gasoline like silicone. It stays kinda tacky, so it doesn't get 'rubbery' like silicone. Available at most every parts store. It's freat stuff....use it everywhere where silicone is not recommended. )It won't get sucked into your intake.
sleeperZ96BT
Sep 9, 2015 08:28 AM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
surreybrad
Jul 29, 2015 02:55 PM
Noct
Jul 14, 2015 01:18 AM
