WTF! antifreeze leaking on oil filter
well i've been smealing antifreeze for a few week's and i thought it was my lower hose clamp(battery acid dripping down).but i noticed A/F on the floor,were the back of the motor would be.so i check it and it's dripping of the oil filter,but i can't tell if it's coming out the bottom of the head or the back!isn't there a hard line that connect's the two head's?help me guy's! thank's
The crossover can be removed without taking the heads or intake off.....of coarse it will be a PITA due to its location.
The tube is bolted on with a banjo bolt and 2 seal washers on each head so if you take it off youll need 4 of the washers.
Jul 4, 2005 05:00 PM
