Wtb: Gm 847?
Old Mar 13, 2004 | 05:53 PM
'94 Bad A Z28's Avatar
Question Wtb: Gm 847?
I am getting the GM 847 and would like to know where I can get a hold of it in a Kit with everything.... and all I could find from GMpartsdirect was this...
2370847 - Hydraulic Roller Design
This hydraulic roller design contains eccentric for mechanical fuel pump. It is for off-road use only. The duration at .050" tappet lift (intake/exhaust) is 234/242; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 539/558. Valve lash is zero/zero and lobe centerline is 112 degrees.
Wouldn't give me a price or anything.
Old Mar 14, 2004 | 08:12 AM
Since I couldn't find a kit with this cam I ordered the cam alone last night, but I still need to order everything else, here is a list of what I htink I need let me know if I am leaving anything out:
Rockers
Springs
Retainers
Spring Seats
Hardened Pushrods
Timing Chain
Lifters
Timing Chain Gasket Set
Intake Gasket Set
I think that is everything, but if not what else? Any suggestions on which parts to get would be appreciated aswell.
Old Mar 14, 2004 | 08:38 AM
slopokrodrigez's Avatar
Not sure if the 12370847 will accept the drive for the opti. You shold investigate that.
Does any of those kits include the timing cover seals? Do you plan on changing them?
The timing gears should be changed too. They come in the HP chain assembly #12370835. But it won't fit 93-94 without changing the timing cover and cam. But you already planned on changing the cam. If you plan on moving up to the vented opti (which for some reason is much less $ then the non-vented) this is the time to do it.
Didn't see if you had an electric WP. If you don't, get the WP drive assy. #10219554 It has the gear, the bearing and mounting plate already on it.
Old Mar 14, 2004 | 08:44 AM
Yeah, I have an EWP already.
Old Mar 14, 2004 | 03:21 PM
bunker's Avatar
Yep it'll work just fine.
sleeperZ96BT
Sep 9, 2015 08:28 AM
thisiscmg
Parts Wanted
Feb 1, 2004 12:53 PM
transamrider007
Parts Wanted
Jan 13, 2004 01:20 PM
SwagonS
Parts Wanted
Nov 19, 2003 08:22 PM
ollie-99
Pacific
Nov 3, 2003 01:28 AM
