Would there be any problems wiring my ignition this way?
Hi. I've been having continuing starting problems for the past 3 months. I've replaced the ignition switch twice, starter and the wiring pigtail on the switch with individual wires.
I've figured out the problem. It is the wiring going to the starter, so now to start the car, I have to turn the key to "on" and jump a hot wire and one to the starter solinoid.
Would there be any problems with running that wire to the starter solinoid and connecting it to the yellow wire on the ignition switch and cutting out all of the stock faulty crap wiring? I already have VATS disabled, so that's not a problem. I just don't want there to be any chance of fires or something not working doing it this way.
Thanks in advance.
Thanks in advance.
Re: Would there be any problems wiring my ignition this way?
Originally Posted by ubiquitus
No, I haven't. Where is it located in the car? It's tricky because it sometimes starts and sometimes doesn't.
I believe I've found the problem. When testing all of the wires at the theft relay, my ignition switch doesn't always deliver 12v when trying to start the car. I believe its out of adjustment. That would also explain why my accessory function behind the lock position doesn't "click" into position.
Does anyone know off hand if the ignition switch should be moved forward or backward to fix this? I'd like as little time as possible upsidedown in the floorboard lol. Thanks.
Oncomingstorm22
Jan 22, 2015 07:15 PM
lbrowne
Nov 13, 2011 04:25 PM
