would a knock sensor cause a check engine light?
Old Apr 29, 2004 | 09:25 PM
  #16
Originally posted by DonHood
We have a light that looks like an engine? I'm pretty sure the only "engine" light is the SES light. Where at on the dash is it located?
He lives in Canada. Export cars got the engine symbol instead of Service Engine Soon. He would also have a symbol that says "ABS" instead of "ABS inop".
Old Apr 29, 2004 | 09:38 PM
  #17
94Zpower's Avatar
Actually you guy's got t he export cars not us the plant where they were built in view of my office window.. thanks for the tips and Ideas guy's, I am gonn start by check the Knock mod and just go from there and see where I get.. and hopefully I can get this sorted out so I can spray my 100-150hp shot.
Old Apr 30, 2004 | 05:37 PM
  #18
19camaro71's Avatar
I think it's pretty cool that you have an actual Canadian Camaro. Good luck with the diagnosis, hopefully it isn't a severe problem!
Old Apr 30, 2004 | 06:58 PM
  #19
Stoopalini's Avatar
Did you get the PCM scanned? What was the code?
Thomas.
Old May 10, 2004 | 10:12 AM
  #20
94Zpower's Avatar
The knock sensor circuit code came up so i guess I will start with what shoebox suggested.
any other ideas??
Old May 10, 2004 | 11:13 AM
  #21
Tony Danza's Avatar
didnt they demolish that factory recently?
Old May 10, 2004 | 12:01 PM
  #22
94Zpower's Avatar
They are in the middle of doing it now!! does any one want some pics??
Old May 10, 2004 | 09:26 PM
  #23
19camaro71's Avatar
I would love to have some pictures... karps@csinet.net ... if you don't mind!
Old May 11, 2004 | 09:46 PM
  #24
Tony Danza's Avatar
well here's one i ganked off of a thread in a local board:
http://www.ls1camaro.net/freehosting/ste.tgone.JPG
Old May 11, 2004 | 10:05 PM
  #25
MaxCamaroZ28's Avatar
If its a problem with your KM acting up trying putting in a LT4 KM its less senstive and won't retard you timing to every pop your car makes, its about $30
Old May 12, 2004 | 02:42 PM
  #26
94Zpower's Avatar
i did swap in a LT4 KM and still have the light so I got another scan at a different garage and it said "Knock circuit" so I guess I will check the messurements as Shoebox suggested.
anything else to check??
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
