would i see any difference going to a 54mm TB?
Old Oct 20, 2005 | 08:42 AM
flusz28's Avatar
right now i have a 52mm throttlebody. would i gain anything going to a 54mm or even a 58mm with my blower setup? if i went 58mm i would port the intake of course. my sig shows what all i have done to the motor.
Old Oct 20, 2005 | 03:08 PM
97pontta's Avatar
Re: would i see any difference going to a 54mm TB?
You would have to port the intake manifold entry holes for the 54mm throttle body also. The intake holes are 52mm stock.
Old Oct 20, 2005 | 07:03 PM
flusz28's Avatar
can i port my 52mm throttlebody too a 54mm?
Old Oct 20, 2005 | 07:34 PM
The Engineer's Avatar
You can machine it out to 59mm without any problems (I've done that). However, you'll need to do some de-burring inside the venturas after you increase the ventura diameter.
Old Oct 20, 2005 | 08:29 PM
97pontta's Avatar
What kind of throttle body is it? If it is an aftermarket unit it can be done I believe. If it is a stock throttle body bored then 52mm is all the larger it can go.
Old Oct 20, 2005 | 10:51 PM
flusz28's Avatar
its a BBK throttlebody. now would i notice any hp gains from porting the throttlebody bigger and the intake port matched?
Old Oct 21, 2005 | 04:34 AM
97pontta's Avatar
A 52mm can support a fair amount of HP, you might see a few but probally not worth the extra $$$. Looking at your mods list you would probally benifit more from a set of long tube headers being a forced indcution engine.
WobblySausage
Oct 7, 2015 02:44 PM
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
