Would this help or hurt on 1le lca brace and panhard
Old Feb 4, 2003 | 07:57 PM
z2894convertible's Avatar
I was thinkng about welding a metal plate over the opening on them to help stiffen them up. Is this a good or bad idea?
Old Feb 4, 2003 | 08:33 PM
Teal94Z's Avatar
SLP sells reinforced stock control arms, and panhard rods with the exact same idea as you are going to try. It will help I am sure, however you still have the stock rubber bushings, and you are adding some weight....might be better off buying aftermarket items...but its your choice
Old Feb 4, 2003 | 08:39 PM
I thought the 1LE had the hardened bushings. Is this true or false?
Old Feb 5, 2003 | 08:50 PM
TTT
Kinglouui
May 26, 2016 11:05 AM
football4life
Oct 4, 2015 07:48 AM
Henson071
Sep 18, 2015 04:01 PM
force10
Jul 30, 2015 04:56 PM
realistyc
Jul 28, 2015 07:32 PM
