Would exhaust hitting the floorboard cause false knock?
Just wondering since I think my Y is definitly hitting. I can feel something knocking around under the car when I accelerate.
BTW- how much clearance is needed between and exhaust part and the body with poly mounts. How much will the motor/exhaust move one way or the other? Sounds dumb, but I know that there is clearance, just not sure how much and have no idea how much the motor moves around with good mounts.
-James
-James
Guest
Posts: n/a
Re: Would exhaust hitting the floorboard cause false knock?
Yeah, my headers are riding on my K member some and it is causing false knock, so it can happen. You need just enough clearance that it does not hit while under hard acceleration and going over bumps.
Originally Posted by BlackLT1_TX
any idea on how much clearance that needs to be. i'd say its got about 1/4 inch. Maybe a little less.
i have poly motor mounts on my LS1, and barely 1/2" clearance on the ypipe and frame right behind the collectors.
so you dont need much.
the engine barely moves 1/4" when reved up with the mounts.
I have probably a 1/4 inch clearance using the BMR k-member with poly mount. I do not have any issue hitting the k-member, but it did hit the tranny crossmember, so I notched that.
I have about a 1/8" cleareance with my JetLT and stock mounts and it just barely hits.
Originally Posted by camaudio
only a 1/4" cleareance with BMR k-member? what exhuast are you running
i had heard that poly motor mounts would give you a tiny bit of clearance. my LT's are rattleing up under my floorboard as well. i'm installing the new motor mounts this weekend. i'll let you know if i still get some rattle.
i have the pacesetter LT's though.
-James
-James
Originally Posted by Zeueses 97 RamAir
did you finally get the car running I retuned and added all new ignition on my car and rewired the computer harness it burned thru and was causing knock on my car..when are you going to the track again I can meet up and maybe we can run them......
i did get her running. i am not getting much false knock, but i want 0. i took down a c6 on i20 a few days back, so i dont think im loosing much due to the timing. my only fear now is my 10 bolt with this power, and since im running a t56 with a spec clutch, its life isnt any easier.
I have a spec stage 3 also and i was wondering does it make like a grinding noise sometimes.....
it always makes some sort of wierd noises
Lol my stupid hooker lts are touching the k-member on the pass side. Hell i had to hammer clearence the header a little just to make if fit. Guess i should have went with poly mounts.
im on my 2nd spec stage 3 in 10k miles, no racing
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
