would this engine work on my Z??
Old Mar 11, 2003 | 04:39 AM
tealdevil's Avatar
http://www.samtaylor.com/html/parts/350_Ho_Engine.htm , will i have any problems with it..
and is it a good engine, also how much to install..
thanxx..
Old Mar 11, 2003 | 05:13 AM
anaik's Avatar
That's not an LT1, won't work.
Old Mar 11, 2003 | 06:15 AM
RacinLT1's Avatar
sure it will "work",BUT.....you cant use the stock computer,you will have to figure out what small base distributer to use.
Also will need to go aftermarket EFI/manifold or run a carb and do some cutting of the cowl.
Not a wise choice IMO,but it is possible with a lot of work.
Old Mar 11, 2003 | 12:16 PM
tealdevil's Avatar
well here is the deal, i have 120,000 on my engien, so its time to get a new one, but somehow i cant find any new LT1, and rebulding is kind of confusing, i did a search and there is planty of types to chose from, all i want a 350hp engine fly not RW..
so what do i need to rebuild it..
thank u for ur help..
Old Mar 11, 2003 | 12:54 PM
Kris93/95Z28's Avatar
Well try to look around there are MANY companies that rebuild LT1s. That would be just as expensive as buying a new engine and having it installed.
You probably could have a 383 for the price of the engine in the link
Old Mar 11, 2003 | 01:15 PM
94_formula's Avatar
120k, it should go more than that and stay strong.!!
oldschool
Feb 9, 2016 09:21 PM
97z28k&N
Jan 9, 2015 04:58 AM
nballisru
Dec 14, 2014 05:01 PM
siguy
Nov 27, 2014 10:07 AM
Snoman73
Nov 17, 2014 07:22 PM
