Would a blown head gasket be worse in the cold?
Seems like I get an awful lot of condensation..not right when the car starts but like 1 minute afterwards it start pooring out. Never looked this bad when it was warm.
You should probably study up on water vapors and what happens between warm and cold temperatures.
If you think a head gasket is suspect you can either keep an eye on your coolant level, check the plugs and/or do a leakdown.
