would 396 fail emissions...?
Re: would 396 fail emissions...?
.... the higher the cubic inches with the stock heads, the lower the emmissions. It will draw more air in and allow it to burn much cleaner. It also won't decrease your mpg to 13mpg. A turbo setup would be much easier to pass than a heads/cam setup. Turbos won't spew out large ammounts of emmissions unless under boost, and even then they do no use as large of cams. The only sneaky way to pass is to pay someone...
