WOT Timing
Old Jul 11, 2003 | 08:15 AM
Viking's Avatar
WOT Timing
How much timing do you guys run at WOT (high loads/high rpm)
I'm having some knock retard from 3000- rpm and up and I cant get rid of it. I have the timing set to 23 deg MAX and still have some major KR.
Engine is 10:4 comp. Tpis ZZ9 camshaft
/N.
Old Jul 11, 2003 | 10:37 AM
LWillmann's Avatar
Have you tried replacing the knock sensor?
I was getting a lot of knock retard and tried several things. Turned out to be a bad sensor.
Looks like between 3700 and 4600 RPM in 3rd gear in mine, at WOT, the car was trying for 29-36 degrees total timing.
Old Jul 11, 2003 | 01:00 PM
Viking's Avatar
Yes, new sensor............
I've tried from 32 down to 20 deg at WOT, still KR probably false knocks.....
But I dont want any KR when I'm adding 9 psi of boost......
Old Jul 11, 2003 | 01:31 PM
LWillmann's Avatar
Have you tried racing fuel? Maybe add a couple of gallons to a half-3/4 tank of what you normally run?
Have you checked that your exhaust isn't tapping anywhere? I have heard that tapping on the exhaust can cause the knock sensor to go nuts, but I don't know for sure...
Does it do it when cold, hot, all the time?
Are you running the LT4 Knock Module?
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
jayblev95
Jan 20, 2015 01:30 PM
blac94Z
Jan 12, 2015 05:44 PM
