WOT rpm problem.
Old Aug 26, 2004 | 07:51 PM
fesgali's Avatar
WOT rpm problem.
The car will run fine till i really get on it, and between the 4-5k rpm range the engine will start "popping" and the rpm will dropto around 2,500-3k rpm and kinda have a bounce between there and the 4-5k rpm. It doesn't matter what gear it's in, but seems to be more prone to right before it's suppose to shift out of 2nd.
Is the "popping" noise misfireing? rev limiter (not sure why it's going off so early)? detonation due to need of new timing (over 100,000 miles)?
Any ideas?
Old Aug 26, 2004 | 07:56 PM
dirtybird96's Avatar
Re: WOT rpm problem.
how old are the plugs and wires?
Old Aug 26, 2004 | 08:03 PM
fesgali's Avatar
not even a year, NGK and 8mm taylor
I'm considering changing out the plugs, get OEM platinum ones.
Any idea on what the popping/stalling is?
MikeWhitener
Aug 2, 2015 06:17 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
asilomar244
Jul 12, 2015 05:53 AM
gonzo275rltw
Jul 11, 2015 04:19 AM
