at wot car vabrates bad
so when i am at wot in 2nd gear around 5500 rpm the car starts to shake and vibrate really bad not sure if this a susp. issue or drivetran, looking for help as to what it maybe or if anyone esle is having the same problem.
thanks
james
thanks
james
i was thinking driveshaft because it onlys happens at wot and in the higher rpms, but i will be reading though this and trying out everything.
i have to do this tomorrow... i have a very similar vibration as you... the more into the throttle i am the harder it shakes... does it from like 55-65 and then again at like 80-85...
Driveshaft vibration is a function of speed, not rpm. If your driveshaft is the culprit, you feel it at while doing 70 mph on the freeway and the engine in neutral (rpms at 650).
it let up a little when i took the rotors off also... probably wouldn't hurt to get new ones...
did you find anything out yet?
or did it just strart doing this
have not had a chance to mess with it yet. i am taking my alum. ds to the shop tomorrow and i am just going to put that in and see what happens.
