worth it ?
Old Nov 17, 2005 | 06:20 PM
corbraeater's Avatar
worth it ?
my brother thinking about get a carbon fiber drive shaft for his 02 SS, and i was going to use he old one cause it aluminum,is it worth it?
Old Nov 17, 2005 | 07:55 PM
FastZinTennessee's Avatar
Re: worth it ?
Yes it's worth it. I don't see how you've gotten by this long with the stock steel "vibeshaft".
Old Nov 17, 2005 | 10:41 PM
LT193's Avatar
Re: worth it ?
Anyone know if they offer and power gains?
Old Nov 17, 2005 | 10:49 PM
Schweet97Z's Avatar
Re: worth it ?
no power gains but, your car wont vibrate anymore!! YAY
Old Nov 17, 2005 | 11:00 PM
bdc95ta's Avatar
Re: worth it ?
they're weaker though
-b
Old Nov 17, 2005 | 11:22 PM
Bersaglieri's Avatar
Re: worth it ?
Its very worth it.
It does in fact give power gains in most situations. The less rotating mass the better. One test showed something like 2hp/5tq at the wheels. Not bad especially if its free.
http://www.ws6.com/mod-1.htm
-Dustin-
Old Nov 17, 2005 | 11:27 PM
CANTONRACER's Avatar
Re: worth it ?
I would just stick to an alum unit.
Old Nov 17, 2005 | 11:59 PM
MyShibbyZ28's Avatar
Re: worth it ?
Once you get enough power it will eventually buckle, same with the alluminum ones. Personally I favor steel, no one is going to be under my car to see the shiny alluminum anyhow.
Old Nov 18, 2005 | 12:02 AM
matLT1's Avatar
Re: worth it ?
Even the aluminum shafts are plenty strong for all but the heavily modified cars.
Old Nov 18, 2005 | 12:08 AM
Re: worth it ?
Take the Aluminum for free. You wont make enough power to break it until about 3 grand from now
-Dustin-
Old Nov 18, 2005 | 12:53 AM
thesoundandthefury's Avatar
Re: worth it ?
Reducing rotating mass whenever possible is always a good thing, but a secondary benefit of having a carbon fiber driveshaft is that if you're running a max effort vehicle, where the possibility of a driveshaft breakage is higher than normal, the carbon fiber piece will just shatter and leave a bunch've strands of fiber, whereas an aluminum or steel shaft runs the risk of puncturing the floorboard or possibly even launching the car into the air.
Whether you'd actually consider owning this to be worth or not is after you'd maxed out your motor and reduced weight in every other area possible but you were still concerned that having an aluminum driveshaft and a driveshaft loop for safety were adding just enough weight to prevent you from shaving that last 1/10th off your quarter mile.
Devinfoote87
Feb 12, 2016 03:21 PM
blaze309
Sep 8, 2015 05:27 PM
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
whitehooptie
Aug 17, 2015 08:35 AM
