Worn GMPP guideplates
Old Sep 28, 2005 | 03:30 PM
qndzia's Avatar
Hi,
I noticed recently that my valvetrain become pretty loud, so I decided to see whats goining on. Under valve cover I saw that almost all guideplates are worn and some of rocker arms are not centered over valve stem, although there is no worn sign on pushrods. Here are pictures (sorry for quality - it's from mobile)
Do I have just bad luck, and should I change these guideplates with other GMPP or should I look for any other possibilities of this situation?
Old Sep 28, 2005 | 03:31 PM
96ta(nick)'s Avatar
Re: Worn GMPP guideplates
Mine did the exact same thing which resulted in a new motor.
Old Sep 28, 2005 | 03:44 PM
qndzia's Avatar
What do you mean? What exactly had happen?
Old Sep 28, 2005 | 04:25 PM
Kurt Crosbie's Avatar
Same thing happened to dhirocz. GMPP guideplates must just suck. Is it only happening on the driver's side?
Old Sep 28, 2005 | 04:29 PM
96ta(nick)'s Avatar
The metal from the plates got in my bearings... Spun a bearing and had to rebuild.
Old Sep 28, 2005 | 05:35 PM
qndzia's Avatar
I've checked only passenger side.. but I suppose the same is on driver's one.
Old Sep 28, 2005 | 07:03 PM
1racerdude's Avatar
What lifter's ya got? Ya got a small base circle cam? Ya getting enough lube to the Top?How much oil pressure? Your push rods the right length? Rocker shaft's installed with the flat side up? Valve covers hitting rocker's causing a side load?
Old Sep 28, 2005 | 09:39 PM
jsetzer's Avatar
I think this is very possible in Nick's case...
Old Sep 28, 2005 | 09:51 PM
1racerdude's Avatar
Could be. Thats some of the things he might check.
Old Sep 28, 2005 | 10:18 PM
stereomandan's Avatar
Were the GM guideplates installed with the "05" stamped in the guideplate facing up?
Dan
Old Sep 29, 2005 | 04:35 AM
qndzia's Avatar
Good questions.. Answers below:
- Comp R,
- it's LE2 cam (by Joe O.), lift 0.569
- yes (800 rpm with slow flow from pusrod - didn't check higher rpm's)
- ok
- stock length 7.2" - didn't check but stock lt1 heads with stock GM gasket - so should be fine, i think ..
- I suppose so, although whole job was completed by mechanic
-I don't think so - valve covers were modified
guideplates has around 4k miles.
Old Sep 29, 2005 | 04:42 AM
qndzia's Avatar
Dan
I don't know, but this cannot be issue as far as rockers are well centered - whole material of plate is hardened IMHO.
IndyZman
Oct 22, 2015 02:17 PM
HarleyZ28
Oct 5, 2015 06:23 AM
football4life
Oct 4, 2015 07:48 AM
Z28-50
Aug 7, 2015 01:22 AM
realistyc
Jul 28, 2015 07:32 PM
