won't warm up?
won't warm up?
lately my temp gauge will only go to 130 degrees and Never any hotter. i thought my thermostat might be stuck open so i replaced it with a new one and still the same thing? not only in winter but also in the summer it just never heats up. any ideas?
Re: won't warm up?
confirm if the gauge is working properly, check the temp sensor in the drivers side of the block and also check the one to the water pump, make sure your fans arent staying on
tdigger9899
Sep 7, 2015 10:56 AM
