Wont start when it rains.
Old Apr 8, 2005 | 07:14 AM
ToocoolZ28's Avatar
My 95 Z28 wont start when it rains. The car has 215000 miles but the opti and plug wires were replaced at 80000. Does this sound like the opti again? Other than that it runs great.
Thanks.
Ron
Old Apr 8, 2005 | 11:32 AM
lookingforwheels's Avatar
Re: Wont start when it rains.
Not sure how long the opti is supposed to last but 135000 seems like a long time.
Old Apr 8, 2005 | 11:47 AM
Fast96WS6's Avatar
Thanks.
Ron
DEFINETLY the Coil. Had the same problem after chaning Opti, plugs, wires. I even had a new MSD coil with less than 5000 miles on it. Whenever it would rain, it wouldnt fire. The new MSD coil went bad on me. Try changing it and see if it helps.
Old Apr 8, 2005 | 12:16 PM
Brian Sutherland's Avatar
I had the same problem it was the coil and ignition wire
Brian
Old Apr 8, 2005 | 12:27 PM
Bersaglieri's Avatar
I'd check out and possibly replace the coil and coil wire to the opti. If its unplugged or damaged it wont start.
-Dustin-
Old Apr 8, 2005 | 01:31 PM
93transam1234's Avatar
COIL
if is not the coil the check the wiring going to the coil
Old Apr 8, 2005 | 02:50 PM
69gto96z's Avatar
Check the boot on the wire to the plug. It might not be covering the plug all the way, and when it rains, the plug might be getting wet, causing it to not spark.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
