won't run smooth after replacing intake gasket
Subscribe
Apr 27, 2003 | 07:19 PM
I just did the intake manifold fix. Now after I try to start it, it won't run smooth. It will barely start, then it will not idle. The car runs like it has air in the lines or something. I don't know how to bleed the fuel lines. Is this what I need to do. Any help is appreciated.
Reply
Apr 27, 2003 | 08:06 PM
You need to check and make sure you reconnected everthing.How long did you let the silicone set up before running it.?The fuel will bleed itself.
Reply
Subscribe
