Won't idle after cam install....
Old Oct 15, 2005 | 06:33 PM
jsetzer's Avatar
Rockers are fine, It is throwing a MAP code, i am thinking my vacuum is too low due to the big cam?
It is a 245/254 on a 112.
Old Oct 15, 2005 | 08:29 PM
Formula_one's Avatar
Re: Won't idle after cam install....
Check the green plug on top of the intake manifold, just behind the throttle body on the passenger side. Mine came out just enough to throw that code. I pulled it out, cleaned it and plugged it back in. All was fine after.
Old Oct 15, 2005 | 08:35 PM
Vicious95Z28's Avatar
Dude,
not much info here. UM 245/254. That's a fairly large cam. Do you have a tune for that cam. It's not likely to idle very happily under 950-1000.
Old Oct 16, 2005 | 10:56 AM
jsetzer's Avatar
Yes it is tuned for the cam, I tried setting the idle all the way up to 1200. Sometimes it will stay there. Most of the time it drops to 500 or so and then dies .
I hooked up a vacuum gauge and it is pulling no more than 10. I could not find any leaks.
Old Oct 16, 2005 | 12:58 PM
DiabloGT's Avatar
shouldnt you use a bigger stall? or is your car manual?
Old Oct 16, 2005 | 01:31 PM
ReNxWar's Avatar
Thank god. The first thing I thought of when I opened this was "My car sputters and won't idle smooth after cam install!"
Old Oct 16, 2005 | 01:56 PM
96ta(nick)'s Avatar
I was posting under a friends name...
It is a manual. My iac counts are in the 150 range... How can i get that down?
Old Oct 16, 2005 | 02:04 PM
faded93bird's Avatar
Look up the Drill mod to the T/B
That will help, good luck.
Cam's maro
Jan 30, 2015 09:21 PM
Britbilly
Jan 7, 2015 08:49 PM
Queens94z28
Nov 20, 2014 06:03 PM
F(ast)-body
Feb 26, 2003 09:05 AM
