Wiring, need help so i can finsih my project
Well i left it to my cousin orignally to disconnect the wires under the steering wheel and all that so that i could help do some stuff underneath the car. Well little did i know he wouldn't label anything or remember where anything went. now i have the chiltons and haynes manuals which help slightly, however, when i bought my car the guy that owned it before me put a remote starter in it. Ive noticed there are 3 wires that are not connected right now. Well actually they are, i connected them Everything works... brake lights, stereo, front lights dash lights fans on the engine all that. The only thing that doesn't work is the starter solenoid. I think i might have put the ground wire to the wrong bolt. Does anyone have a picture or something of their wiring in their car or some kind of guidance. You have no idea how badly i want to drive this now that everything is in.
There is all kinds of wiring stuff on my Tech Page. On the starter solenoid, there are only 2 wires that should be connected. The large positive cable to the large lower terminal and the purple wire to the outside small terminal. There is a small black/white wire that is a ground, but it goes to the engine block on a stud below the #6 spark plug.
Henson071
May 4, 2015 12:23 PM
