wiring LED for performance shift mod
Old Jul 27, 2003 | 04:32 PM
chevyboy_z28's Avatar
woohoo, i finally finished the performance shift mod thingy but to my disaapointment the shifts arent what i thought they would be. i mean you can tell the difference but its nothin to make a big fuss over. anyway how am i supposed to wire the LED light. on shoebox's link it says he wired his to the fuse box, but how do i do that. what wire will i need to splice, and how do i get to it. i tried to make it work by wiring it to the defrosters gray wire but that didnt work (i think thats a ground wire and i need a positive source). all who have done this mod and wired an LED where did you wire it to. (i.e. wire "H" on white connector in kick panel to what?)
Old Jul 27, 2003 | 05:57 PM
You can actually connect it to the orange wire of the cig lighter and it will work fine. BTW I did not author that diagram or the remarks.
Old Jul 27, 2003 | 06:08 PM
shoebox what does the "H" wire on the white connector control anyway, it seems like that wire has nothing to do with the switch?
Old Jul 27, 2003 | 06:29 PM
It's only purpose is to provide signal so you can see that the performance mode is active.
Old Jul 27, 2003 | 06:40 PM
Saptio's Avatar
what is the performance shift mod and where can i find out how to do it?
Old Jul 27, 2003 | 07:00 PM
shoebox i wired the LED to the "H" on white and the orange from the cigarette lighter fired it up pressed the button and the LED didnt come on . whats the problem, why is this giving me such a hard time ?
note: earlier after i got the wiring to the switch right, i wired the led to the same source as the switch (i.e. "A" on blue connector), and the LED came on (even before i pressed the switch...as soon as i started the car), but if i pressed and held the momentary button the LED would go off. so i know the LED works, i just cant seem to find a source that will cut it on when i press the button (line H on the white connector isnt working)
Old Jul 27, 2003 | 07:15 PM
Does your LED have a red and black wire? If that is the case, connect the red to the orange and the black to H. If it still does not light, test the LED again and if ok, check H with a meter to see if you see a ground on it when the button is pressed the first time after the key is turned on.
Saptio: a search should find you some info. Ask again if you do not find it.
Here is a diagram of what is being discussed.
Old Jul 27, 2003 | 07:54 PM
the LED doesnt have any wiring coming out of it, it just has two flat metal prongs with holes in the middle, coming out of the bottom. i tried to make it work by splicing into the line from "H" going into the LED, and routing it to the neg. on the cigarette lighter, and on the other connector on the LED i had the wire going to the pos. of the c. lighter...still not working. i wired the LED back to the "A" wire on the blue connector just to make sure it still works and it did, so i am starting to think that the "H" wire on the white connector just doesnt work or somethin, is there any other wire i can use?
Old Jul 27, 2003 | 08:03 PM
H is the only wire that will provide the signal. Perhaps your connection to it is not good. Remember that you must connect the same end of the LED to the orange wire that you used when you tested it and it worked. The LED will not light if the + and - sides are reversed.
Old Jul 28, 2003 | 11:19 AM
shoebox today i went up to radio shack and got a 12v LED with a built in resistor and wired it up, and it works. i turned the car on pressed the button, and the LED lit . but how does this switch actually work. once you turn the switch on you cant turn it off until you turn the car back off, b/c when i press the switch and the LED lit i pressed the switch and the LED did not go off, but when i turned the car off the LED went out, how does this work/spposed to work?
Old Jul 28, 2003 | 11:28 AM
Mtrhds94Z's Avatar
Each time you push the button, it turns it on[if it was off] and off[if it was on]
Also each time the Ign is turned off it goes off[if it was on]..
Old Jul 28, 2003 | 05:42 PM
MentalCaseOne's Avatar
Heh Hum.... since I am a kinda different kinda child.... I am Special I mean... I did not use the cig lighter nor the fuse box for the positive side of the power juice...
I GOT TO THE RADIO WIRING!!!! I figure if I make a mistake and do a shortcircuit I will know exactly what fuse I have fried and it will not be in any possible way related to the PCM.. Worst that can happen is the radio will loose power.
HaHa... thats what happens when I have too much time on my hands....
Oh by the way... I think you fryed your first led dude.. and yes the leds have a polarity... plus and minus.. they arent light bulbs they are Diodes.
Congrats on your new mod... everybit helps
Marvin
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Dec 3, 2014 12:30 PM
Jul 4, 2005 05:00 PM
