wiring CSI?
Old Oct 25, 2003 | 12:12 AM
DarkRider's Avatar
wiring CSI?
Just got my CSI elec. water pump. Wandering how ya'll wired it or the best way to wire it.
Also I saw on summit that there was an elec fan wiring kit for $30 - didn't think i'd need it - thought I could do it cheaper.
Any sugestions.
Thanx
Josh
Old Oct 25, 2003 | 12:19 AM
NiteRider's Avatar
Sounds like you stole my name junior, give it back or i'll punch-a-size your face.
What's with cowboy G talk anyway?
Wiring is easy, grab yourself a relay to and follow up the directions. Mine had a detailed sheet with the best way to do it.
Old Oct 25, 2003 | 12:25 AM
DarkRider's Avatar
haha - im from texas so cut me some slack here - plus my csi did not coem with any wiring insructions.
Old Oct 25, 2003 | 12:35 AM
AsianSensation's Avatar
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
Old Oct 25, 2003 | 12:51 AM
DarkRider's Avatar
I am also doing the opti - do you thind I should go ahead and do the timing chain? Car has 90,000 on it.
Old Oct 25, 2003 | 12:58 AM
craigffb's Avatar
That's pretty much how I wired mine up, except I ran the wires under the box instead of all ****y like that guy did. I also used empty spots in the fuse box for the relay and fuse. You wouldn't even know I had a CSI if you didn't look.
Old Oct 25, 2003 | 01:09 AM
I don't know about the CSI but I had to use a 1LE elbow with my Meziere. Might want to get a Vortech or Trick Flow elbow if that's to your liking if you have not already done so.
HarleyZ28
Oct 5, 2015 06:23 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
lbrowne
Nov 13, 2011 04:25 PM
97FormulaWS-6
Sep 11, 2002 11:57 AM
turbo_Z
Aug 19, 2002 10:50 PM
