wires
Old Apr 1, 2008 | 10:21 PM
snareman's Avatar
wires
going to put mac headers on my 93z. anybody with them tell me how to zip tie them, because I want to use my msd 8.5 wires.dont want any burnt wires.send pics to if you can. also if anyone has used heat resistant wires let me know the kind you used.thanks snareman
Old Apr 1, 2008 | 11:31 PM
94zgreenmachine's Avatar
I have used the DEI heat boots. They worked great. I had MSD 8.5 with Edelbrock shorties and I never had a burnt wire and I didn't have to zip tie anything.
Old Apr 2, 2008 | 08:27 AM
z275plus's Avatar
Red face
I ran msd's in the stock location when I installed my pacesetter mid length headers and everthing worked out fine so far.
I used the bracket that held the stock wires and had plenty of room.
Old Apr 2, 2008 | 10:41 AM
2000GTP's Avatar
Hard to say exactly what you'll have to ziptie, just look over all your plug wires really well and also wiring harnesses as well and make sure nothing is coming in contact or too close to the header primaries. If something is,then zip tie away from the primary as best you can.
Old Apr 2, 2008 | 10:50 AM
Jazsun's Avatar
Do you suggest using heat wrap on some harness wires for longtubes? I was reading some writeups and some people seems to put heat wrap on just about every wire near the primarys.
Old Apr 2, 2008 | 11:48 AM
My long tubes offer better clearance to plugs than the shorties did. I now use nothing, but I have Taylor wires with over the valve cover wire kit. It works great.
Old Apr 2, 2008 | 11:59 AM
ReNxWar's Avatar
Over the valve cover wires are the best. Looks better and makes sure they're safe.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
