Will a water pump leak show up under a presure test ?
Old Jun 14, 2003 | 05:29 AM
Van5150's Avatar
Will a water pump leak show up under a presure test ? The coolant magically disapears, if I bring it to have a pressure test on it, will a water pump leak show if it was leaking ?
Old Jun 14, 2003 | 09:24 AM
Josh-'04 GTO's Avatar
If you want to see if the water pump is leaking, why don't you get under the car and see? When mine was on the way out, it was leaking from the weep hole. It was plain as day.
Old Jun 14, 2003 | 10:21 AM
TMDZ28's Avatar
yes it will. i did it on mine, and the pump starts leaking.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Sandersen511
Jan 13, 2015 03:49 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
