Will a vented cap work on a non-vented?
Old Sep 19, 2006 | 05:45 PM
dlricker's Avatar
I have a 93 and was just wonder if its possible to put a vented distrubutor cap on to replace my non-vented. Thanks, Daniel
Old Sep 19, 2006 | 11:08 PM
Re: Will a vented cap work on a non-vented?
Yes, though you won't be able to take advantage of the venting unless you convert the housing, too.
Old Sep 20, 2006 | 10:11 AM
autoxr's Avatar
The MSD cap and rotor kit converts the 92-94 optis to vented. The kit supplies the vacuum tubing, and the instructions say to fill the vent holes (on the bottom of the opti plate) with silicone. One vacuum line goes to the intake manifold, the other goes to the intake elbow. The instructions say to punch a hole in the intake elbow for the vacuum line fitting, but I've found it's much neater to just use an elbow from a 95-97 that allready has the hole there.
Old Sep 20, 2006 | 02:51 PM
plattted's Avatar
There is an article written on this . See Corvette Fever, Feb,2001 PG. 20 titled "OPTI-SPARK Options" for venting these distributers. The venting harness is GM part #304688.
*Emilia*
May 13, 2015 09:05 AM
CARiD
Jan 14, 2015 04:00 AM
Red_94Formula
Parts Wanted
Dec 6, 2014 11:07 PM
Jul 4, 2005 05:00 PM
