Will these fabricated valve covers fit my LT1?
Old Aug 11, 2007 | 07:03 PM
CrazyJim's Avatar
Member
http://store.summitracing.com/partde...5&autoview=sku
From summit... I'm assuming ANY centerbolt valve cover will fit?
Old Aug 11, 2007 | 07:21 PM
wrd1972's Avatar
If its going in a F-body then the answer is no, the passenger side cover must be clearance d to clear the altonator. Cover that will fit will be center bolt that specifically fir the f-body.
Old Aug 11, 2007 | 07:22 PM
CrazyJim's Avatar
Member
My bad, I meant to include the fact that I'll be relocating the alternator down lower with a relo bracket:
Old Aug 11, 2007 | 09:06 PM
Projectz28's Avatar
Moderator
Dont bother... I bought those and then returned them because they didn't fit. Nice covers but they just dont fit. The tubes for the bolts are too long and they didn't sit right on the head. I could have cut the tubes down but the covers were still not fitting the rail very well. Search for my name and summit fabricated valve covers. You will find some pics I posted about them. They dont fit a LT1 head very well.
Old Aug 12, 2007 | 02:53 PM
CrazyJim's Avatar
Member
Thanks for the info... While in my search I've found better quality Canton's from VRE for cheaper
Old Aug 12, 2007 | 05:03 PM
Projectz28's Avatar
Moderator
Yeah the cantons fit. If your already dropping the alternator you can get the standard SBC covers from Canton also to avoid any rocker interferance.
Personally I needed a cover like that to clear the Jessel SS shaft mounts I used. I ended up buying a set of used SBC fabbed covers here and then went out and bought some new hardware.
BTW, just incase you were still looking for some pics:
http://web.camaross.com/forums/showt...ght=fabricated
Old Aug 13, 2007 | 12:15 AM
sn8ke eatr's Avatar
if you looking for fabbed covers for lt1s ebay has some pretty good deals. i dont think i would want a cover without breather holes tho especialy if its a hopped up motor that sees high rpms.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
Jul 4, 2005 05:00 PM
