will stock manifold bolts work on headers?
Re: will stock manifold bolts work on headers?
Originally Posted by Bawls
yes but i wouldnt. Just buy a set of Breslin's.
I agree 100%, the Breslins are GREAT!! They will cut your install time down too.
Are they worth the $$? They are not cheap. Breslin Pricing
To answer the original question, NO, the original bolts with their 9/16" heads will not fit. New headers come with 7/16 head bolts. I'm satisfied with my stainless ARP header bolts and they use 3/8 socket for more clearance.
Only TPiS longtube headers use manifold type bolts with 9/16 heads.They have tubes welded on where other brands have just holes in the flange. Most are 3" but a couple are 2".
Not too many guys running them as they're in the Kooks price range.
http://web.camaross.com/forums/showt...ts+part+number
Go Breslin. I would get #600-101 1" length, 3/8" Height, but the length you want may depend on which header you are getting.
IMO, I would advise against the Breslins. A friend of mine ended up stripping the small allen bolt in the middle and made it almost impossible to remove the bolt. Seems like so much work when a standard 1" ARP stainless bolt will work just fine. When you have headers, it's easy to re-tighten them anyway after a heat cycle or two. I'm using stainless ARPs, and wouldn't use any other bolt, especially for that price.
