will this setup work with hotcam
Old May 3, 2003 | 08:19 PM
kcz28's Avatar
i want to know if these springs and retainers are proper when used with a hotcam.
Old May 3, 2003 | 08:21 PM
Robert95z's Avatar
Old May 3, 2003 | 08:22 PM
kcz28's Avatar
forgot to add info.
- Hot tank and thoroughly inspect cylinder heads
- Combustion chamber cleanup to improve burn pattern and increase flame speed
- Port match intake and exhaust ports to increase flow
- Resurface heads to desired compression ratio
- Pro Street 3 angle valve job
- Ferrea 5000 series valves 1.94” intake/1.56” exhaust
- Comp Cams dual valve springs
- Lightweight retainers and machined locks
- Viton valve seals
- Set all valve spring pressures and heights
- Flow bench test with print out
- Fully assembled head, ready to bolt on (core required)
Old May 3, 2003 | 08:53 PM
BPS's Avatar
BPS
you either have to provide the spring specs or part number as comp cam makes a number of dual valves.
DirtyDaveW
Dec 1, 2016 05:37 PM
InfernalVortex
Jan 17, 2015 09:35 AM
WildRidez
Jan 16, 2015 03:10 PM
