Will Rockers make THAT much diff *part 2*
I have 1.55 RR's and CC305...
my friend has 1.6 RR's and CC305
he's saying that the 1.6 makes at least 15RWHP over the 1.55's.. Others say thats not true.... I don't think this is the case either...
what do you guys think? will it make THAT much diff If i was to go with 1.6 over 1.55s?
the difference between a 1.55 and a 1.6 RR is going to be negligeble. Look at what people gain going from stock 1.5 stamped rockers to 1.6 RRs, maybe 7-10 rwhp. so going from a 1.55 that's already a roller tip to a 1.6 isnt worth it. It might net 3-4rwhp.
Originally posted by turbo_Z
i think the gains from roller rockers come from the friction reduction of the bearings more than the increased rocker ratio.
Turbo_Z: That's pretty much right.
Also, when switching to roller rockers, the main benefit comes from the reduction of friction via the roller fulcrum (the center section), not the roller tip. I recommend Comp Cams 1.6 Pro Magnums. If I had to go back, I would get non-self-aligning rockers and guideplates.
If you want to find your lift after installing 1.6 ratio rockers, the CC305 is 510/510 lift on a 1.5 ratio rocker arm. 510 * (2/3) * 1.6 = 544.
Hope this helps,
JR
Hope this helps,
JR
Tell your friend you dont think they will make a difference, so he needs to let you try his. Take it to the dyno. If it makes 15 RWHP or more, then you buy a set. If not, you laugh at him and tell him he can't have them back, cause it doesn't make a difference.
