Will a ported intake make a big difference??
Old Jul 20, 2007 | 08:46 PM
  #16
my94blackz's Avatar
Also thinner the walls, faster it will cool.
Old Jul 20, 2007 | 09:39 PM
  #17
tnmotown's Avatar
Originally Posted by rickreeves1
Does anyone know if LE has ported one of the Edelbrock air-gap manifolds yet? I was wondering how it turned out?
im curious too! does the Edelbrock manifold have the same size runners as stocks or are they a little bit bigger?
Old Jul 23, 2007 | 12:08 AM
  #18
wrd1972's Avatar
Lloyd chared me $200, it looked great.
Old Jul 23, 2007 | 10:46 AM
  #19
rickreeves1's Avatar
http://www.edelbrock.com/images/home/new_products.pdf
"RPM AIR-GAP® INTAKE MANIFOLD
FOR 1992-97 CHEVROLET LT1 AND LT4 V8
Utilizing the proven short-runner tunnel-ram design for 1992-97 LT1 and 1996 LT4 engines, these
manifolds incorporate a .250" longer-than-stock runner and our patented Air-Gap™ design that delivers a
cooler, denser air stream for maximum power from 1500 to 6500 rpm. The throttle bore inlets are cast
larger than stock to accommodate our 52mm throttle body #3809 or our 58mm throttle body #3810. The
LT1 version, #7107, is designed for use on factory LT1 heads or Edelbrock LT1 heads #61909. #7109 for
the LT4 is machined with a .250" taller port designed for use on factory LT4 heads, Edelbrock LT1 heads
#61909 and the new Edelbrock LT4 heads #61939.
RPM Air-Gap LT1 (for 1992-97 LT1 or Edelbrock LT1 heads)............................................ .........#7107
RPM Air-Gap for LT4 (for 1996 LT4 or Edelbrock LT4 heads)............................................ .........#7109"
Noenav
Mar 1, 2019 07:38 AM
MadMav
Feb 6, 2015 11:02 PM
Jul 4, 2005 05:00 PM
Maverlck32
Aug 19, 2002 11:45 AM
