Will a ported intake make a big difference??
Old Jul 19, 2007 | 12:23 AM
tnmotown's Avatar
I was just curious if porting out my intake runners would make a good difference in power?
My mods are in my sig, and as for now my TB openings are only ported for the TB, but not the intake runners. The heads i have are stage 3 cnc fully ported and gasket matched.
Im i losing some power with the stock ports and if i ported my intake runners would i see a good gain?
Old Jul 19, 2007 | 08:23 AM
Z-RATED94's Avatar
It can't hurt, but I would let someone that knows what their doing have a go at it. I wouldn't expect more than 5 to 15 HP though.
Old Jul 19, 2007 | 09:23 AM
Joe B's Avatar
Yea....let someone like (Lloyd Elliott) who's real familar with what a true "full port" on an LT1 intake is, do it for you.......Even most of the shops "advertised" fully ported LTx intakes that I've personally seen, have been lacking pretty bad in areas("especially" BEHIND the throttle body holes where many do almost nothing) and many guys ruin the important runner angles during the runner porting)...........The LE fully ported intake was about the last thing that was done to my combo.....It picked up a solid 2 MPH at the track on an already very consistant running and tuned car, and you could immediately feel the difference from 4000 RPM's up(with zero torque loss down low).....I would think your combo should pick up even more than mine.............Joe
Old Jul 19, 2007 | 11:21 AM
tnmotown's Avatar
how much does Lloyd Elliot charge to fully port the intake?
yeah i see all these ads on ebay where they are fully ported by "machine shops" but scared that they might not do a good job.
So you think somewhere around 5-15RWHP with an LE ported intake?
Old Jul 19, 2007 | 05:39 PM
Z-RATED94's Avatar
Well if Joe B gained 2mph, thats nothing to sneeze at. I'm not sure how much mine helped me. Although I went the cheap route and did not have it fully ported. But I must say, for what I paid, he did some nice work. And by the way, his work was so nice, until I held it up to a stock manifold, I couldn't tell what had been done, then I saw difference in the ports. That's how nice the finish was, it still looked like a stock finish, only smoother.
Old Jul 19, 2007 | 05:48 PM
tnmotown's Avatar
its just seems like to me that i've done almost all the mods on my car that i could of done, but yet still have the stock intake and not ported.
I was just thinking with ported heads and stock intake, im losing some power there
Old Jul 19, 2007 | 09:36 PM
dangalla's Avatar
he only charged me 200 ontop of the h/c kit, not sure what he would charge if doing the intake only
Old Jul 20, 2007 | 01:16 AM
tnmotown's Avatar
i emailed him today about it and he said the same price. He said that he cuts up to 3lbs of aluminum off the manifold!! that seems good to me
Old Jul 20, 2007 | 08:42 AM
Z-RATED94's Avatar
Sounds like a plan. And if a re-build is in my future, I'll have mine fully ported by Lloyd.
Old Jul 20, 2007 | 01:40 PM
Don 97 SS's Avatar
Talking
3lbs! That is alot of material being removed Amazing.
Old Jul 20, 2007 | 05:50 PM
fireman's Avatar
I have a ported/welded LE intake on my car. He adds metal just above the injector bosses on the outside if the intake in order to remove more inside the port. I believe this "raises the roof" of the port for more/better flow.
Very nice piece, I know I am not seeing the full benefits of this intake with my stock, unported heads. The car does seem to put down some good numbers though..
Old Jul 20, 2007 | 07:44 PM
tnmotown's Avatar
well im seriously going to get a ported intake soon by LE. I just have to find a spare intake somewhere so i can keep driving my car while its getting done. Then once the ported intake is on, dyno-tune the car..yeah!!
Old Jul 20, 2007 | 07:55 PM
rickreeves1's Avatar
Does anyone know if LE has ported one of the Edelbrock air-gap manifolds yet? I was wondering how it turned out?
Old Jul 20, 2007 | 08:01 PM
RedLT4Mike's Avatar
I had Lloyd do my LT4 intake when he did my LT4 heads.
From what I saw in the before and after, it was worth it.
I don't think I could live with myself if I didn't have him
port it after he did all that work on the heads.
It just wouldn't make sense.
Old Jul 20, 2007 | 08:19 PM
dangalla's Avatar
that was my thoughts exactly, and for only 200, cant go wrong
